I'm trying to hunt down where (if?) Storm Watch being active is emitted from the local Powerwall API. My best guess is on the grid_status API there is a fairly new "grid_services_active" field but mine always returns false and I have no way of simulating Storm Watch
If your system currently has Storm Watch active (not enabled but actually active due to some immediate outage risk) could you either run this curl command or get the .json result from https://<IP>/api/system_status/grid_status where <IP> is your local Powerwall IP? You'll have to click ignore on the certificate error to do so the browser route, the curl -k flag suppresses that error.
Thank you!
Code:
curl -k https://<IP>/api/system_status/grid_status
Thank you!
