According to the Tessie app, I get 340 Wh/miWhat's your lifetime efficiency if you don't mind me asking
The fitment looks perfect in this photo. Do you have any more pictures that show the amount of poke? The offset seems pretty aggressive, but it looks like the drop from the KWs tucked the tires in nicely. Thinking about doing this same setup.Thanks to @TheTheocracy, answering any questions I had! AFF7 20x10.5 +35 squared wrapped in 275/40R20 Continental DWS06 plus. Lowered on KW coiloversView attachment 847448
The hub bore won’t change because of width, if that’s what you’re asking.One person said you need rings for the 20x9x but do you need it for the 20x10.5s or are the 10.5s a straight fit for the Model Y?
so hub ring is needed correct? I've never bought aftermarket wheels before.The hub bore won’t change because of width, if that’s what you’re asking.
I have the MYP so spacers would be recommended correct?You don't NEED one. The lugs will center the wheel but it does make things easier to line up. 64.1 ID to 73.1 OD hub ring works with the Aodhan's. If you have performance model rotors then you also need to clear the exposed hub lip when using a hub ring. There's lot of info about that in the wheel threads.
You have four options that I'm aware of.I have the MYP so spacers would be recommended correct?
I had no idea what a hub ring is. That said between your description and the previous picture in this thread.. it's much easier to figure out by looking at these pictures I have posted below, back to back.You don't NEED one. The lugs will center the wheel but it does make things easier to line up. 64.1 ID to 73.1 OD hub ring works with the Aodhan's. If you have performance model rotors then you also need to clear the exposed hub lip when using a hub ring. There's lot of info about that in the wheel threads.
*** SPECIALLY MADE FOR PERFORMANCE MODEL 3'S AND ALL TRIMS OF S / 3 / X / Y**** ***(set of four)*** 73.1mm OD. Make sure your wheels have a 73.1mm centerbore before purchasing. PRO TIP: Apply anti-seize to the outer diameter of the ring before installing in your wheels |
Actually what do you think about these for non-Performance Model Y's? Seems to have everything you recommend and sold directly from Aodhan! Polycarbonate material so Im guessing they wont stick to anything! $9 each.. so $36 all around.You don't NEED one. The lugs will center the wheel but it does make things easier to line up. 64.1 ID to 73.1 OD hub ring works with the Aodhan's. If you have performance model rotors then you also need to clear the exposed hub lip when using a hub ring. There's lot of info about that in the wheel threads.
Love it! I have this on mine too, but just 19x8.5. Want to paint my calipers, but haven't gotten around to it!View attachment 866037
20x9 et30 and 20x10.5 et35
Wanted to go 20x10.5 in the front but it wouldn't clear the way I'm lowered.
Thanks! I honestly really love the way these wheels look on our cars. The blue calipers are nice but I should have gone with yellow since my plates are black and yellow. Didn't do it because my model 3 was already black and yellow. Oh the regretsLove it! I have this on mine too, but just 19x8.5. Want to paint my calipers, but haven't gotten around to it!
I am thinking burnt copper for my calipers...everything else, like yours, is black.Thanks! I honestly really love the way these wheels look on our cars. The blue calipers are nice but I should have gone with yellow since my plates are black and yellow. Didn't do it because my model 3 was already black and yellow. Oh the regrets![]()
That would be nice. Honestly almost any color would look good on a black car. So you can't go wrong with whatever you choose.I am thinking burnt copper for my calipers...everything else, like yours, is black.
That's sick, what are you lowered on?View attachment 866037
I'm lowered on MPP coilovers. Wish they went a tad lower in the rears. I maxed out in the rears but fronts can go lower. I wanted to tuck tires but its just barely there lol. I left the front like that to match the rears. They definitely feel better than my model 3 which is on bags. Not much of a difference but i can feel coils are superior. And I never heard about having to match the lugs to the holes, only to bolt pattern. I'm not sure if there would be an issue but I can also be wrong. In my experience with aftermarket wheels, never had an issue with that. So I don't think lug size matters and only bolt pattern. Well technically it matters depending on your cars bolt pitch to have the correct ones to bolt the wheels down. Anyone else could chime in if I'm wrong.That's sick, what are you lowered on?
My only question is wouldn't Advan gt premium 5x114.3 fit the Y
I heard about having to match the m14 lug holes?
Thank you for your time
