After a recent install of a new heat pump, I have gotten a couple of High DC Voltage errors on the heat pump. I am trying to determine if this is in any way related to my solar/PW operation. 7.4kW solar w/ 2PW's, Gateway2 and SolarEdge Inverter.
I track the Gateway data via a RPI using the api/meters/aggregates in Grafana. For some reason I can only get the battery frequency out of the API. Load, Site, and Solar frequencies always show 0.0. I have logged directly into the Gateway and pulled a snapshot of api/meters/aggregates and can verify that ONLY the battery frequency is ever available.
Reading other threads here, it appears that all 4 frequencies (Site, Load, Battery, Solar) should be available.
Any thoughts on why these frequencies might be missing?
Partial sample attached.
