It's not time-efficient to slow down; the car is using power at a slower rate than the SC can inject it. (This sentence is NOT true for L2 charging.) There's always a benefit in drafting, moderate temps, and a tailwind.
This gets repeated on these forums, and it sounds good (meaning it's the answer we want to hear), but I don't know if it has been actually tested much. Sure, the logic sounds good and the math seems to work out, but I'm not entirely convinced. Maybe it's from so many years of slowing down to save fuel. It reminds me of the diesel pickup owners who will swear up and down that they get the same fuel economy at 85 mph as at 65 mph. Ask for their data, and they can't produce it. It's what they have heard, and it's what they want to believe, so that becomes their truth.
Maybe if, on this trip, there are those who want to go fast and those who want to go the speed limit, two groups can set out to put it to the test!
I understand how this may seem counter intuitive but you have to throw out what we have been conditioned with ICE cars because the point isn't about fuel efficiency (which applies to both EV and ICE still) but how quickly can you refuel. With gas, it is not an issue since it takes a few minutes to refill an empty gas tank. Not the same with Superchargers. Charging from a lower SOC will dump juice into the battery must faster initially then tapper off. It takes about an hour to fully charge a MS. Unless you can drive faster than 200+ miles/per hour, a SC is going to refuel you faster than you can use it up.
For example, I've driven up the 101 from SoCal to NorCal several times now. On my last trip, I decided to ignore efficiency and just focused on hitting every SC, charging enough to get to the next SC with a comfortable buffer and then going 70-75 mph. I was definitely not fuel efficient but I only spent about 30 minutes or less at each SC and made it back home faster than driving slower.
Yes, I can see that the difference between driving 70 mph and 80 mph between Superchargers is about 15 minutes. If the difference in the amount of time it takes to charge sufficiently to drive 80 on the next leg vs. the time required to charge sufficiently to drive 70 is less than or equal to 15 minutes, then I get it.
It just seems that the increased speed is causing the drag to increase exponentially, causing a disproportionately high usage rate. The increased amount of charge required, both due to the increase in required stored power to make the next leg at the higher speed and the fact that the battery charges slower as the SOC increases, will significantly increase charge time.
Forgive me, I'm not lucky enough to have a Tesla to play with yet. It just seems like multiple factors working against this fast-driving concept being accurate. I have read of those who have tried it successfully, but I have trouble wrapping my brain around it. The flow-out-while-driving being slower than the flow-in-while-charging sounds reasonable on the surface to me but it's more of a mantra than a rule.
I guess my prescription is to get a Tesla and do some research for myself. :biggrin:
Trust me, I have tried it many times and it is overall faster to drive as fast as you can and charge more at Superchargers. Here is some very simple numbers:
driving 100 miles at 65 takes 91 minutes and uses 31 kWh. To recharge that a Supercharger (doing 100kW) needs 18.6 minutes. Total time: 109.6 min
driving 100 miles at 85 takes 70 minutes and uses 43 kWh. To recharge that a Supercharger (doing 100kW) needs 25.8 minutes. Total time: 95.8 min
You spend 7 more minutes at the charger, but you saved 21 minutes on the drive. Pretty straight forward.
I just discovered this thread thanks to Chickensevil and I echo his sentiment. Looking forward to meeting everyone in Maryland! Good luck on the coast-to-coast drive - I can't wait to hear the stories!
Of course you're going to run into problems with more than two cars arriving at a 4 pedestal SC.
I brought this up earlier, and apparently they are not going to worry about it. I think it is more of a social event than a real attempt to set any records. :biggrin:
