I've done some searches before posting but other than a couple of mentions, my questions are not fully answered. So here goes... I have a new MS60 that I took delivery last Friday. I have just started to utilize the audio/sound system and I have a few questions and/or issues. I have the upgraded system...
1) When I have the option to turn on the expanded sound field (I forgot the exact term; dolby or sound expansion...something like that), the overall sound is thin/weak; I need to turn the volume up, and even then it seems less than high fidelity. I have little bass, even with the EQ set nearly max for bass. If I disable the expanded sound thingy, I get much more fuller sound, lots more base, and overall a much improved sound experience. Also, with the sound expansion OFF, the center sweet spot is odd in the fact I have to have the front/back fader set to almost be tottaly on the rear speakers to achieve a nuetral front to back. If I turn ON the expanded sound it is almost centered front to back in the nuatral (0) fade position. Is this what others are experiecing?
2) I have an Apple iPod plugged into the USB port. It sees the device, but I have no control over it. I must do all music starting and selection from the device itself, and not from anything on the Tesla UI. Is this normal? Seems odd since my BMW would control the same iPOD as if is was part of the music library in the car; I never touched the iPOD but did all music selection and playing from the BMW controls.
Thanks,
Mike
Thanks,
Mike
