AEB in its current form is intended to keep you from running into other cars.
Right now Autopilot doesn't have any protection against road damage, debris, or objects on the road that aren't cars.
Hopefully that'll change soon, but right now it'll happily run into a cone or a deer. The only car I know of that won't is a Subaru with eyesight - and that will only stop short of impact up to about 40 mph.
Yep, no, I believe that it was functioning as intended. at 75 mph, the rules are different than at 25 mph.
And instead of complaining, may celebrate the fact that the autopilot was able to maintain driving of the car while you were asleep!! The option in many other cars would have seen you running into the semi or the guard rails, flipping over and causing all sorts of collateral damage and death.
It is also intended to keep you from hitting a human, a bicycle and a motorcycle. Those are the things mentioned in the manual as examples. They can't list *everything* that can get in your way. 3 of those 4 examples are metallic objects that can be seen with radar (and cameras), but the human object can only be detected with the cameras. So if it can detect a non-metallic object the size of a small child then I would expect it to recognize an object the size of a 50-gallon barrel (also non-metallic). Is this an unreasonable expectation?
Wow, do you have pictures of the front?
Fred
Its an unreasonable expectation to think that you can fall asleep (even for a short time) in a vehicle you are driving at 75 MPH and be surprised about damage, instead of being happy to be alive.
So you came out lucky. Take that minor damage as a learning experience that you need to follow the instructions that are given to you when you operate a car.You could easily miss the damage that it caused. Slight deformation of the front bumper, dent in the hood that's only visible at the right angle, destroyed mirror and scratches where the mirror slammed into the driver's door. There was also some damage under the car, cracking a coolant hose which caused a leak in the battery coolant (lost 3 of its 6 gallon coolant capacity in 2 days).
Don't put words in my mouth. I never said or implied that falling asleep goes without consequences. I'm saying that I expect AEB to recognize something the size of a 50-gallon drum when it can recognize something the size of a small human.
@Wingsy Thanks for posting. Glad the outcome wasn't worse and for the reminder that the software, regardless of name, is still a driver assist not a replacement
FSD with version 3 hardwareI have had the EAP change lanes for barrels at 40 mph. Did the OP have AP or EAP?
The thread title is also AEB "failure" implying a fault in the system when there apparently was none.
I must have missed that. Can you show me where they state that AEB has reduced functionality at higher speeds? I thought Autopilot was good up to 90mph.
Saying that, you still seem to be saying "why didnt the car protect me from myself, is that an unreasonable expecation?" and its my position that, right now, with current software and abilities of the car, it is somewhat unreasonable.
