After spending several hours pouring over previous threads regarding how much weight can be placed on the factory installed hitch receiver, I remain confused. The latest MY manual I found on the interweb (2020.44, Oct 29,2020) says:
"The hitch receiver is designed to support vertical loads up to 160 lbs (72 kg). When carrying bicycles, skis, or other items on the Model Y hitch, always check to ensure that the maximum weight is not exceeded. When calculating weight, remember to include the weight of the accessory carrier. For example, assuming the carrier weighs 40 lbs (18 kg), the weight threshold is sufficient for carrying two bicycles weighing approximately 60 lbs (27 kg) each, or four items weighing approximately 30 lbs (14 kg) each."
Is there any actual Tesla documentation out there that reduces that 160 lb limit to 120 lbs? This is critical to my purchase decision. I have two bikes that weigh 55lbs (sans battery) and need recommendations for a rack that works on the MY. Anybody out there that transport two heavy bikes on their MY and have found a hitch rack that works well? Thanks for any recommendations.
