Best way to clean lower window sill trim?
Discussion in 'Model S' started by brycerocky, Aug 3, 2018.
  1. brycerocky
    brycerocky Member
    Santa Clara
    Landscapers at work went to town with the leaf blower and now I have a nice collection random stuff stuck in my lower window sill trim (against the glass). Other than use my own leaf blower at an angle, any suggestions on how to clean this area?
  2. P85_DA
    P85_DA Supporting Member
  3. brycerocky
    brycerocky Member
    Santa Clara
    See below. stuff didn't fly off driving ~35mph. My current thought is handheld leaf blower and then wipe with microfiber and detailer?
  4. P85_DA
    Use a cotton swab with rubbing alcohol ..or get one of those sponge paint brushes
  5. Don TLR
    Don TLR Active Member
    Apache Junction AZ
    Compressor to blow air in and dirt out??
  6. brycerocky
    brycerocky Member
    Santa Clara
    Does the rubber trim react to the alcohol? I've seen other materials turn cloudy on contact.
  7. quickstrike12
    quickstrike12 Member
    Fort Worth Texas
    Just a simple vacuum cleaner with the wedge shaped narrow nozzle will do the trick. Or even better if you have the small round brush attachment for vacuum cleaner that comes with many shop Vacs that’s the best.
    This is what I use to clean the air vents and crevices around screens and dash etc...... works perfectly and it’s very gentle. Compressed air of any kind just “relocates” the dust and dirt somewhere else
  8. P85_DA
    Nope I use in vents ..even warm water and soap should work
  9. Brettski
    Brettski Supporting Member
    Palm Desert, CA
    +1 on the vacuum cleaner with the brush attachment. I had the same issue and it worked very well.
    I’d be worried about solvents on rubber pieces - could backfire!
  10. hydro
    hydro Member
    Québec
    Best and only efficient way is to remove that chrome piece and clean it then reinstall. Had the service Center show me how to do it. Just pull on it from the door’s edge. It won’t break.
  11. P85_DA
    Up or towards you ?
  12. barjohn
    barjohn Member
    Riverside, CA
    I used an old tooth brush and that worked just fine.
  13. brycerocky
    brycerocky Member
    Santa Clara
    Just as an update: freeway driving home + dewalt compact blower on max got almost all of it out.
