Bike Rack Ground Clearance
Discussion in 'Model S' started by brutewolf, Sep 14, 2020.
  1. brutewolf
    brutewolf Member
    Oklahoma
    I've seen several threads where people have discussed the use of hitches and bike racks. The users seem to be pleased, but my concern is ground clearance, which I haven't heard anyone address. I have a Kuat NV 2.0 bike rack (for my other car) and was considering the EcoHitch for the Model S.
    Can anyone who carries bikes discuss your experience with scraping the pavement or other nightmare scenarios?
  2. Subgdubb
    Subgdubb Member
    Maryland
    I use a 1up Bike Rack with a 2inch receiver Ecohitch. It's a bit low but generally fine. I use the air suspension for big curbs and in certain spots to keep it from scraping, but it's not a big deal. You get used to it.
  3. krsgio
    krsgio Member
    Colorado
    I didn't want to go the hitch route due to reading about rust issues so I'm currently using sea sucker mount to transport my bike.
  4. gbailey
    gbailey Member
    Arkansas
  5. domodan
    domodan Member
    UT, United States
    I went this route as well. Works great and I can still get in the rear hatch. The car is low enough that I can even pull in/out of my garage with the bike on the roof.
    ABDEC26A-1A19-4CC3-B500-2A2028B5679D.jpeg 454F92A0-01B9-4B98-83DC-A8D25F5E7AB6.jpeg
  6. FatherTo1
    FatherTo1 Member
    I tried risers in the past on my Lexus LS sedan and, although it keeps the bike rack higher, the bottom of the riser itself will hit the ground. The riser actually increases the chance of me contacting the ground because it sticks out more and I feared the impact gets transmitted to the hitch and car frame. I think it's best just to raise the suspension when the situation requires.
  7. Subgdubb
    Subgdubb Member
    Maryland
    Inspiration
  8. tpoltron
    tpoltron Member
    Cupertino, CA
    Better to drag a sturdy riser on the ground than a much more delicate bike rack. You want a riser that steps up, with a short lower portion - definitely not one of those over/under dual receivers. Happily been using a riser and 1up for 7 years on our S and 2.5 on our 3, which has even less clearance and no air suspension.
  9. brutewolf
    brutewolf Member
    Oklahoma
    Thanks for the responses. My previous S had no active suspension. I'm about to order a new one (waiting for battery day). Is there a noticeable difference with the suspension elevated?
    Which leads to the next question...what does it do to range? Has anyone taken one on a long trip?
  10. FatherTo1
    FatherTo1 Member
    The speed is limited in High and Very High. Off the top of my head, I think it starts lowering to standard height somewhere between 14-19 MPH.
    Edit: The limits have been raised because i distinctly recall it being 19 MPH for one of the settings before:
  11. FatherTo1
    FatherTo1 Member
    I wasn't referring to just dragging. I accepted the dragging part and glad it worked for you. OP will just have to test it. From my experience, if the driveway or road is a tad too steep then the bottom of the riser hits the ground "head on" and is literally pushing against you and not just dragging on the ground. I was all excited when I got the riser and thought my problems were solved but I just got a different set of problems. The riser can definitely work but you won't know until you try it. For me, it wasn't the solution I hoped it to be and I was particular about getting a riser with the shortest extension I could find.
  12. krsgio
    krsgio Member
    Colorado
    I've driven 600+ miles and at speeds up to 90 mph without any issues if anyone was curious. Range wasn't impacted too much unless you're going thru Wyoming then the wind/speed kills your wh/mi. I normally travel with it lower on the rear glass like gbailey's pictures.
