I know the bore size is 64.1mm and bolt pattern is 5x114.3, ET +40mm. If I use hub-centric rings can I use any bore size larger than 64.1? And for the ET, I should subtract ~6mm per .5" increase in wheel width...i.e. stock is 8.5" and ET40, so 9" I should goto ET34mm is correct?
