2109 MX Raven Standard Range. The hinge pin on the little spring loaded door on the floor that conceals the trunk latch hook worked its way out of the plastic tab on one side. As a result it got off center and the force of the trunk closing seems to have broken off the plastic tab that holds the other side of the hinge pin. So the little door is loose and just flopping around. To fix it, the whole bottom part of the trunk trim in that area will have to be replaced as the tabs are molded into it. Has anyone else had this issue? Does this sound like it will be covered under warranty?
