Swampgator
One oz of ground beef contains 6X the protein and fat of corn. And protein from plant is only absorbed at a rate of 2/3 that of protein from meat. So practically speaking even in your example corn is only twice as water efficient as beef at a nutritionally equivalent par level.. But, corn does not contain the essential nutrients that beef does. There is no B12 for example in corn. B12 is essential for humans. So plant based animal products need to be fortified chemically. Have you calculated the costs of those additions upstream of the Beyond process? Additionally, corn is deficient in essential amino acids like lysine. So even if protein levels are matched to beef, the protein quality is inferior for human consumption.Data follows, but the top level look is that sunlight energy turns into plant calories, which are converted into flesh growth on animals. Obviously there is an efficiency loss at each step along the way. The lower on the food chain you go, the less wasteful you'll be. In feedlot agriculture, they refer to the conversion ratio as a Feed Conversion Ratio, of FCR. Beef has an FCR of 6:1 or higher. Nutrition density varies, of course, between dry feed and live weight gain, but in most cases they use FCR at the feedlot, so the grain of choice is dried corn. From a caloric perspective (recognizing that calories are not the only measure of nutrition, but are the measure of energy conversion), an ounce of dried corn has about 110 calories, and an ounce of ground beef (80%) has about 71 calories. So in this case, our non-water inputs are 6*110 calories (660) of corn to achieve 1*71 calories (71). That's extremely inefficient, but of course it is. Cattle ruminate. They move, they live. They expend energy, and they cannot be 100% efficient at conversion.
What hasn't been included in this is the amount of water needed to grow an ounce of ground beef (112 gallons) vs corn (8 gallons). What else? Waste ponds, meat refrigeration and storage, spoilage waste (which is much higher with meat) and animal transportation.
Now as for corn finished beef vs pasture raised, that is a whole other can of worms. But grass fed is definitely less resource wasting than corn finished, and the nutritional profile of grass fed beef is far superior to grain finished beef, especially the omega 3/6 ratio.
Calories are a terrible measure of nutritional content. If all that maters were calories we could all sit around and drink coca cola all day to meet our nutritional needs. Sadly, some do.
