The way I read that is that the problems only start if you are connecting to a 3-phase supply, using a Gen1 charger with the blue adapter?
Other way around: problem arises when you are connecting to a single phase supply but the Gen1 UMC makes the car think it has 3-phase.
Does it follow that a single phase supply via 3-pin plug should be ok on either version? (Gen1/Gen2)
You would expect so, but I don't think anybody has reported testing the Gen1 adapters to be sure. You could check it quite quickly with a multimeter. (Actually, *I* could check it quite quickly with a multimeter as I now have a Gen1 UMC 13A plug adapter, which I didn't last time this was discussed. Be right back....)
Edit: No multimeter required! On inspection, the Gen1 UMC -> 13A plug adapter doesn't even have contacts in the connector for the other two phases, so this adapter definitely can't cause the problem seen with Renault Zoe, and is almost certainly OK to charge any EV. It is probably only the 32A blue commando adapter for the Gen1 UMC that is problematic, though I haven't tried all the others to be sure.
