Since FSD Beta 10.12.2 (2022.12.3.20) I have been unable to choose between Speed Limit or Current Speed in the Autopilot controls. I need to be able to select Current Speed. Anyone else have this problem?
Our Y LR got admitted to FSDb in min-June. Since then the setting you mention has been greyed out. But for my wife's profile, it is frozen one way, and for my profile, it is frozen the other way. The way mine is frozen is not the setting I had when the FSDb software was installed.
No I don't have a solution--just answering your "anyone else?" question with Yes.
Using "Current speed" for autopilot, the offset choice is now greyed out and I am unable to set AP to go +10 kph above the speed limit. If I use the "Speed Limit" option I can now select an offset, but this will set it so AP will ALWAYS speed up to the speed limit +10, instantly. Is this a bug...
teslamotorsclub.com
It's nothing to do with an update glitch, but rather an either or option (they don't tell you about) with set at current speed vs speed offset. I think that is why your speed offset is greyed out.
