bradtem
Robocar consultant
Yup, I know about most of these. It's definitely skating on the edge, though. No ability to take detours. No ability to even take a wrong turn and add 10 miles to your trip. And not much better when you get into Alaska except on the Anchorage to Fairbanks axis.Yeah, the thin charging infrastructure in N BC will slow you down, but not really too much, if you travel in the summer season. Red Goat Lodge and RV park on the Cassiar is EV-friendly, but it's 255 miles (411 km) from Boulder Creek Rest Area, the closest DCFC to the south. However, you could make it from Prince George in a long day and 230 miles of range with a couple of extra stops. In addition to the faster options allong the Yellowhead Hwy., Meziadin Jct has some level 2 capability during the summer season. Then you'd want to stay overnight in Iskut (Red Goat) anyway. From there, Watson Lake DCFC is "only" 212 miles (342 km). The hitch then becomes the area around Glennallen/Tok, in interior AK. However, Tok has an electric school bus, and a guy willing to let you charge there at 20 kW, I think; if you make prior arrangements (Stretch Banchard, of Tok Transportation). Check PlugShare. RV parks can provide charging there too, in summer...All of this of course depends on having a working adapter, either Chademo or CCS support...
Yeah, it's possible, even necessary to stop at the rare RV park with 50a plugs, and pick up 60 miles in 2 hours, and that can make a difference. But now we're moving into the "major compromise compared to gasoline" realm. I always try to see if I can make using the EV better than a gas car, not worse. Today, for an Alaska highway trip, I would still consider a gasoline car rental, in spite of the higher cost. (Much higher cost since rental is so expensive up there right now, which could flip the question the other way.)
But I think before too long this should get fixed. Some DC Fast every 150 miles on the Alaska Highway would be a nice thing to see.
How does the Tok bus guy get you 20kw? The charger in my car is only 7.2kw, does he have a 20kw DC charger?
From what I can see online, Meziadin has only TT-30 so it would take a very long time to fill you up to get to Red Goat. Which is also TT-30 so even loading up a full 230 miles will take 24 hours, not just an overnight stay. And will you make Watson lake? Can't be sure. There are some RV parks not in plugshare between East Pine and Fort Nelson, where overnighting with 50a will do the job, but from there it's TT-30. Unless you can be sure to pull off that "Y" trick (which still only gets you 20mph, so you need a 10-11 hour stop) this is a hard slog.
But it will improve.
