Charge port door won't register as "closed"
Discussion in 'Model S' started by gzerninplatz, Apr 23, 2017.
Tags:
  1. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    I close the door, it sticks to the magnet, but I don't hear the "clunk" and "charge port door open" shows on the dash...not always, and it usually eventually shows as closed...
    Any ideas?
  2. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    I would say your only options are reboot and then call the Service Center. Reboot is hold down the two steering wheel thumbweeks, of course, until it does. :)
  3. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    My real question is- has anyone else seen this issue, and if so, what was the cause and cure?
  4. benjiejr
    benjiejr Technogeekextraordinaire
    San Antonio, Texas
    Sounds like the charge port needs to be replaced to me, but I usually get an error similar to the following:
  5. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    I don't get that error-just the note that it is open...
  6. benjiejr
    San Antonio, Texas
    Just a guess that it needs to be replaced... not sure why an error is not detected, but maybe whatever detects the error is broken. Log it with the service center and I bet they replace it. Quick job.
  7. snellenr
    snellenr Member
    Houston
    I've had this happen at Superchargers before. It's especially irritating when it results in a "Charge door is open" alert as you drive away from the charger (maybe 50% of the time).
    My workaround "habit" is to close the charge door manually after removing the charge wand (hear magnet click, but no port-lock thunk), reopen the door using the wand button, and then reclose the door (now I hear both the click & thunk).
    Edit: March 2014 P85, in case that's relevant.
  8. tinm
    tinm 2013 S85 Owner
    New Mexico, USA
    Yes I have had this issue. (2013 S85.) Seems like there is a state the software can get in where its "belief" as to the actual state of the chargeport door does not comport with reality and is in fact the complete opposite. It happened maybe 18 months ago and I immediately called Tesla's 800 number. Can't remember what did the trick to fix the problem but many reboots and occasional tapping Open Charge Port button from the charge display on 17" screen.. something made it right again.
  9. EVie'sDad
    EVie'sDad Member
    Newark, CA
    I experienced this late last year. The cause turned out to be that i had just washed the vehicle and had failed to dry the inside of the charging port. Yes it does prevent you from leaving the charging stall, but that is user error. Dry and clean the inside of the port and you should not see this problem anymore. Never had an issue since.
  10. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    Thanks for these ideas...but they don't seem to apply...the locking clunk doesn't happen, so the message is accurate...however, just did a long trip, and Supercharging seemed to fix it...I get the "clunk" and no message...maybe the heating from Supercharging loosened up whatever wasn't moving...we'll see as I switch back to my wall charger this week...
  11. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    Well...I brought it in, and based on my description, they replaced the charge port. They decided that it was the sensor behind the magnet in the port. It only gave the message when it was cold out, and we are now in a hot spell, so it may be a long while before I can truly know it is fixed...(they didn't replace the charge port door, which they think is OK).
  12. Spyder14
    Spyder14 Member
    Bluffton, SC
    Just got this message an hour ago. Will try a few things but just drove through huge rain storm so I will dry it out & see.
  13. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    If you re-glued the magnet in the chargeport door, it has an orientation to the one in the other side. If not oriented properly it will give an error.
  14. Randaddy
    Randaddy Member
    Bay Area
    I have the same issue with my charge port (non powered). Dash and MCU will intermittently show "charge port open" but door/release button are fully functional, the port has never physically opened on its own. It first appeared intermittently during winter rains but now that the weather warmed up, the alert is back and stays on longer before going away on its own.
    Local SC took a look and told me the only thing that would cause intermittent alerts is the charge port magnet/sensor. Tech was unable to reproduce the error by wiggling/tapping the port door, but ordered a replacement charge port/door assembly anyway.
  15. stetsoninc
    stetsoninc Member
    United States
    I did have a situation where the magnet separated from the chargeport door. I did re-epoxy the magnet on and certainly put the magnet back on with the "dirty" side being epoxied to the door. Is there any more of an orientation that that? However I am getting the error chargeport door open after trying the reset steps....thoughts?
  16. Lloyd
    San Luis Obispo, CA
    Yes there is a rotational orientation also as well as side. The service center will need the replace your door. They did mine when I made the same error.
