I am new to Tesla, I just got the model 3 long range not too long ago, I have a question about the charging port door. Do you guys find the port door closes too quickly after you unplug the charger? I am using the 32A 240V Mobile Charger on 14-50, here are 3 cases I tested:
Case A: After the charging is completed and my car is LOCKED.
(A1): I used the app to Open the charging port door and then
(A2): Unlocked the charging port
Result: When I pulled the charger out, the charging door closed SO QUICKLY, like within 0.5 seconds. If I do it slowly, it actually hit the charger.
Case B: After the charging is completed and my car is LOCKED.
(B1): I used the app to UNLOCK the CAR DOORS, and
(B2): Opened the charging port door, then
(B3): Unlocked the charging port
Result: This time, when I pulled the charger out, the charging port door stayed open for 10 seconds, and then automatically closed by itself.
Case C: After the charging is completed and my car is LOCKED.
(C1): I walked to the driver door with my phone and unlock the door physically, door remain open.
(C2): I used the app to Open the charging port door, then
(C3): Unlocked the charging port
Result: When I pulled the charger out, the charging door closed SO QUICKLY again similar to case #A which is annoying.
Do you guys experience the same? Wondering why can't the charging port door always has a delay like Case B? I can't seem to find a setting on this. I have updated to the latest firmware 2021.44.25.2 and the behavior is the same for older firmware I had before. Any insight would be appreciated. Thanks!
R.B.
