The 6 in 6-20 refers to a 240 volt circuit.
6-20 means you can use 12/2 wire ...
Wire is labeled by the number of conductors, not including ground. 12-2 is Line 1, Line 2, and Ground. 12-3 is L1, L2, Neutral, and Ground.You should use 12-3 wire -- Line 1, Line 2, and Ground.
When there is talk about the impact on the grid of electric cars, there isn't talk about how much work it can be for an older property to have a charger installed. Older houses were not built anticipating the level of electrical usage we are now at and EVs are going to stress that further. I think my panel replacement and new kitchen electrical cost about $8000.
Tom,
Thanks. that makes a lot of sense. I am at least going to get a quote. If the quote is too high, then I'll just do it.
Don't tell them it's for an EV. Tell them you want to install an RV 50A 14-50 outlet for when your brother visits with his RV. If it's close to the breaker box, it should cost < $250.
-Scott
Waaay back Martin posted details about charger signalling on his now defunct blog. Did anybody per chance keep a copy of that? I'm looking for the nitty gritty on how the Roadster knows the max charge (amps) it can draw. I seem to remember something with pulses but am in the dark about voltages, timing, etc.
There should be a universal law against taking down blogs and web pages in general.
If you know the URL, try this site: http://www.archive.org/web/web.php they may have an archived version.
