Thanks guys for the input! Yes it will be plugged in inside my garage. I don't have anything else plugged in or running overnight, so hopefully I'll get on the high end of the spectrum. 5ish would be great - I would have it plugged in about 12-14 hours...I only have to drive about 20 miles round trip so I'll be golden.
The fact that you dont have anything else plugged in, in the garage, doesnt mean that is a dedicated circuit. In my house (for example) the garage outlet on the wall is also shared by my garage door opener, and every plug on the rear of my home on the outside (where I plug in my BBQ).
Your best bet would be to get a circuit tester (here is an example but you could get one similar at any big box (or local) hardware store :
https://www.amazon.com/Sperry-Instr...595708397&sprefix=circuit+test,aps,190&sr=8-5 )
Plug it in, then push the button to see if it trips a gfci. If it does (light goes out) then you can find the GFCI its on in your home and know that at least that one plug is on the same circuit. If it doesnt, find your main breaker box, then try to identify what circuit that garage plug is on by turning off circuits labeled garage or something close, till the lights on the tester go out.
Once the lights on the tester are out, plug in the tester to other outlets in your home (or on the rear outside) to see if any other outlets are out.
Might sound a bit tedious, but worth it to know what is or is not on that circuit. Most likely there is something else on the standard 5-15 in your garage, unless it was a line run specifically for something or other (dryers are usually dedicated lines for example).
You really want to know what is on that circuit before you start "maxing it out" by using an EV charger. Electricity generates heat, so its always good to know whats going on with an outlet, especially a regular one, that you plan to use for charging.
