the electrician re-tightened the 14-50 receptacle this afternoon and replaced the breaker......for 45 min charging everything was ok.....will complete the charge from 40% to 90% tonight and monitor the charging graph in teslafiThe voltage won't drop during the taper at the end of the charging. If you the voltage dropped to 226v mid charge even after the car reduced to 30a then either you had a wiring problem or an electrical service problem. I would bet on the issue being a bad/loose connection before I would bet on it being a bad breaker.
