will do this afternoon when electrician comes to check the install.....I believe it is a bad breaker or loose connection at the pigtail......
well the electrician came by and I went through all the the things that I did......then I showed him the data from teslafi.....we proceeded to take our the 14-50 receptacle and re-tightened all terminals......then we looked at the panel breaker....it looks good....no heat build-up and just a little discoloration but that was expected.....we changed the breaker......by changing the breaker, it automatically re-sets the HPWC unit.....
we then applied power and watched as the charger booted up......
plugged into my MS and for 45 min watched....
charger booted up to 40a and 233v.....it stayed that way......
we measured the heat at the panel breaker, NEMA 14-50, pig tail wire to the charger, and the wire from the charger to the handle.....all were between 78F - 95F
during the 45 minute period, it did stay at 40a and 233v.......currently I am at SoC 49% and will charge to 90% tonight...
if the amperage and voltage stays consistently the same throughout the charge, I think we can say that it may have been the breaker or the re-setting of the charger fixed this issue.....
last night I reset charger by pushing the reset button.....charged my wifes car (which had the same issues) and charger stayed at 40a and 233v for the entries charge of 1.5 hrs but did drop to 30a and 226v for the last 10 minuets....I wonder if that is due to the slowing down prior to completing the charge.
will report later on how my charge goes after 2100 from 49% to 90%
