For general maintenance, the best thing you can do is simply use a damp (with plain water) microfiber towel to remove dust and minor debris; if you need something a bit stronger for spills/etc. check out CarPro Inside (can be used on basically any interior surface):
If you want to follow up with a dressing for the dash you can use CarPro Perl; since it is water based it can be diluted to your preferred level of shine:
One thing I would caution is to never spray any product directly on the 17" screen or instrument panel display; spray your cleaner on a towel and then wipe off the screen.
Hope this helps! If you have any questions about cleaning specific types of stains/etc. I would be more than happy to lend some advice.
OH wow! I just noticed that you are the one I spoke with via email regarding the scratch on my rear quarter panel. Thanks for the advice and I'll try the inside cleaner.
My Tesla friend uses eScreen to clean the screen and all of the smooth glass-like surfaces. It's a spray bottle with a microfiber cloth designed for HDTV's - www.escreencleaner.com.
