As I said -- CO2 absorbs energy because the molecule is the same size as the wavelength of IR light in certain frequencies. That captures some of the light as it goes by (in and out). That's how it heats up. It reflects that vibration to nearby molecules -- also air and up high, that can only heat up the air up high. Not the oceans down low.
Thus you dodged the point -- how does that make the ocean get warmer -- when there's almost no energy transfer between a gas and a solid. (The less dense, the less energy can be transferred). So you still haven't explained how CO2 can heat the land/water more than it heats the air. And since the water and lange is heating more than air -- it's showing that the theory is wrong or incomplete. Something else is going on.
P.S. The comment about Faux News is dumb distraction and irrelevant. And the guy explaining this failed to mention all the other counter factors... like warming causes more clouds, clouds reflect light, and thus the albedo of clouds is highly under debate and could offset any warming effects. CO2 is plant food and came from the atmosphere originally... so as we raise its level, we get more flaura to absorb it -- that's how the system self corrected for 5 billion years despite not having 400 ppm of CO2, but 7000 ppm and yet we had ice ages and cooled down. And so on.
Here's a video that gives you an idea of some of the problems:
