This morning when getting ready to reverse out of my garage, the car did not respond to the slight press of the ‘gas’ pedal that usually gets it to s slow roll. So, I pressed a little harder on the pedal, and it started to budge but that was followed by a loud “clunk”. Not super loud, but it felt like something had given way.
After pulling all the way out of the garage, I found this thin metal rod on the garage floor under what would be the front right half of the car. I don’t remember seeing this in the garage floor just the day before the car was parked there.
One end is threaded (left side of 1st photo). The other end, which also appears to be bent, looks to have been sheared off. So I am guessing that this may have been the part that broke, causing the ‘clunking’ sound. The dia. is approx 1/16” - 3/32”.
Does anyone recognize this part from the underside of a Model 3? Thank you.
