I can only suggest that the rubber of summer tires “looses” grip in colder weather (below 44F/7C) and if you mix this with water or other natural debris on pavements (like leaves of tree or plants) your sharp direction changes on slow speed “jumps” suddenly giving you unexpected sounds from suspension section. If this ONLY occurs on slow speed, you are fine. If not, have it inspected.
And what is different if using winters tires is that this rubber compound grips much better with cold temp. Better to look other discussions here in TMC about why to change for winter tires...
