Selling my M3P and have the following (all in great condition) for sale.
Custom spring rate BC Racing Coilovers (12kg F, 11kg R). These are NOT the same spring rates BC usually makes them and is actually much more compliant and comfortable than stock. Works out great IMO for California streets while still being really fun in the corners. AutoRND helped me dial these in, just slap them on and you're good to go.
Less than 12k miles on them, will come in original box and spanner wrenches
$875
Megan Racing Rear Camber arms. Already adjusted to maintain stock camber when used with the coilovers(already height adjusted) above.
$120
SSR GTX01 19x9.5 square fitment +35 offset (with 5mm spacers for a very flush stance). Wrapped in Advan Apex 265s tires. I put 3 coats of ceramic on the wheels before having the tires mounted. Really helps with the maintenance of keeping them clean. I also have the center caps, I just didn't like the way they look and never put them on. One wheel has a small chip on the spoke from road debris, but other than that are in perfect condition with no rash. Will include black wheel locks/lugs
$2550
Located in Huntington Beach, CA
New item by Tommy Tibajia (UmmaGawd)
$875
$120
$2550
