hi folks,
i have to report strange behavior of my 2.0 signature (185 kW version). cold weather seems to limit power although the battery is warm.
yesterday it was 8 °C/47 F outside and i started with a rather cold battery also around this temperature. of course the car delivers only limited power - 100 kW - then as expected. after an hour the battery was cosy warm at 20 °C/70 F and even warmer later (75 F) but i could not suck more than ~ 120 kW. what might be the reason?
after this trip i immediately recharged the battery with about 40 miles (16 Amps current) and then set off again straight away. now that charging was stopped full power was available with the usual acceleration.
i have observed this behavior several times. the car doesn't behave this way when it's warm outside or - as i remember and mentioned above - immediately after charging.
but limiting power makes no sense when the battery is warm, even at freezing outside temperatures! this is weird, man...
any idea?
thanks!
Holger
any idea?
thanks!
Holger
