It does not look like it fits very well so might go over the existing liners. Although they shouldn't need to. This will work to reduce road noise. Someone may have determined that rear liners don't do much.
There are also some trunk liners for the underside of the hat shelf that would probably make a difference.
For Tesla Model 3 Car Rear Trunk Soundproof Cotton Mat SoundProof Protective Pad | eBay
Just as a note it may affect bass from audio.I might just buy the rear one because it looks so much nicer than what it is now.
Good point. I'd probably cut a hole for the grill and then use a rubber trim seal to clean up the cut.Just as a note it may affect bass from audio.
I don't think it will. Low frequency sound easily passes through thin materials. Remember that the subwoofer already sits behind the trunk liner in the Model 3. Bigger concern is probably proper HVAC airflow from the cabin to the exhaust flaps under the rear bumper. But this pad looks like it will sit half an inch or so away from the rear deck, so it will probably let air pass on the sides. If not you could cut some openings.Just as a note it may affect bass from audio.
Okay who wants to be the first guinea pig?
Pair of Front Wheel Arch Soundproof Cotton Protective Pad Mat For Tesla Model 3 | eBay
Looks like it is 2 as there are a left and right with no option to choose if it is really a single pc. I think it is just a mistake by the seller, my guess anyway.$86 bucks for ONE Matt?? I thought the price was steep for 2 Matt’s which the picture shows.....but if you read the description it says ONE Matt? That’s “LUDICROUS”!!!
Ski
In the product title it says "Pair" so I am assuming that "Number of Pieces: 1" means 1 pair.$86 bucks for ONE Matt?? I thought the price was steep for 2 Matt’s which the picture shows.....but if you read the description it says ONE Matt? That’s “LUDICROUS”!!!
Ski
Small difference, but noticeable especially on the smooth road, and frequency is different. Would have been nice to hear on a wet road, cause I would think the wheel arches would make more noise then.Professional soundproofing model 3P...... very small improvement.
