I find it interesting that there is not much variation between peak ($0.085) and off-peak ($0.066). (This is also not the full rate, but the additional amounts appear not to vary by time or choosing fixed vs TOU.) So, I looked up the schedule (
https://www.bge.com/MyAccount/MyBillUsage/Documents/Electric/P3_SCH_RL.pdf) and they define their times as follows:
So, a really large peak, and a small difference between peak and non-peak means the savings are probably going to be small when fixed-rate service is listed as $0.073.
But this all seems to be academic as the above rate does not seem to be compatible with NEM. Note in the above link that the list of applicable riders does not include #18. As seen for standard residential service -
https://www.bge.com/MyAccount/MyBillUsage/Documents/Electric/P3_SCH_R.pdf - rider #18 is net energy metering. This suggests that you cannot use their TOU rate with NEM, so you would likely only get a wholesale rate, which would almost certainly make it worse. BGE should be able to confirm this, however.
