Curious increase in miles while driving!
Discussion in 'Roadster' started by bart513, Dec 2, 2014.
Tags:
  1. bart513
    bart513 Active Member
    East Hampton
    I was driving to work this morning which is 135 miles from home. The temp was 40 degrees F and I kept the heat off as long as I could to eek out the miles to get to work. I was down to 51 ideal miles and 42 real miles when my toes were a little to icy so I turned on the heat and then hit the recycle air button. All of a sudden my ideal miles went up to 66 and my real miles went up to 57 respectively! It maintained the gain in miles and went down accordingly until I reached my destination. Any clue why this beautiful increase occurred???
  2. hcsharp
    hcsharp Active Member
    Vermont
    Did you accidentally switch to range mode without noticing? That would add about 25 mi instantly.
    If only the estimated miles changed then it could have had something to do with your consumption because it's based on the last 30 miles of driving. For example if you got off the highway, slowed down to 40 mph for a while the estimated miles could have increased a bit. But it's not that because you said both figures changed.
  3. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I side with Henry here an accidental switch to range mode sounds right. Nothing else quite adds up.
  4. bart513
    East Hampton
    Anything is possible but I think that when in range mode the VDS reads "Maximum Range" or something like that on the battery icon. Idk how to switch into range mode while driving? I was on the highway the whole time and turned the fan switch on as the temperature dial was already on heat, then hit the recirculate button.
  5. dhrivnak
    NE Tennessee
    You can switch to range mode by taping the battery icon while driving. Yes it should say Max Range when you do this.
  6. bart513
    East Hampton
    In fact Henry was correct! Just got to the car and it says max range. Strange thing is I didn't hit the VDS screen but then again....
  7. slcasner
    slcasner Member
    Sunnyvale, CA
    Before the feature to switch modes by tapping on the VDS was implemented, it was possible to switch modes (perhaps only on 2.x?) by turning the key to the "start" position again. But I would think you'd know if you had done that, too.
  8. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The key turn thing toggles back and forth between Performance and Standard, not Range.
