I noticed that the phone App of ABRP (A Better Route Planner) already provide trip consumption for the five Cybertruck versions.
ABRP uses the following 'Reference Consumption' values (See also Battery and range comparison chart #21)
I wonder how much those numbers are meaningful.
In Particular, the Range Extender should certainly affect the consumption
because of the added weight, but this doesn't seem to be the case?
However, I used the ABRP App on a trip between Seattle and San Diego (1265 miles or 2,000 km) and found the following results
And the trip duration for this 1265 miles / 2,000 km trip were as follow
Note: Except for the longer charging time for the RWD with 250 miles range (5 hour),
there is nothing really magisterial between the different versions.
Still the Range Extender saves 37 minutes over the almost 4 hours of charging otherwise.
To get more realistic results, I think that the 'Reference Consumption' values need to be adjusted,
in particular because the impact of the Range Extender on the consumption is still unknown.
"Tesla Cybertruck unveiling" by u/Kruzat, modified by Smnt is licensed under CC BY-SA 4.0.
Admin note: Image added for Blog Feed thumbnail
Reference Consumption | |
Cybertruck Rear Wheel Drive | 431 Wh/mile @65 mph |
Cybertruck All Wheel Drive | 439 |
Cybertruck All Wheel Drive Range Extender | 439 |
Cybertruck Cyberbeast | 462 |
Cybertruck Cyberbeast Range Extender | 462 |
Average Consumption | Energy Used | |
Cybertruck Rear Wheel Drive | 456 Wh/mile | 608 kWh |
Cybertruck All Wheel Drive | 470 | 625 |
Cybertruck All Wheel Drive Range Extender | 471 | 650 |
Cybertruck Cyberbeast | 492 | 654 |
Cybertruck Cyberbeast Range Extender | 492 | 654 |
Total Time Driving Only | Total Time Charging | Number of Charges | |
Cybertruck Rear Wheel Drive | 19H 54 | 5H 7 | 16 |
Cybertruck All Wheel Drive | 19H 35 | 3H 44 | 12 |
Cybertruck All Wheel Drive Range Extender | 19H 45 | 3H 9 | 10 |
Cybertruck Cyberbeast | 19H 35 | 3H 58 | 12 |
Cybertruck Cyberbeast Range Extender | 19H 47 | 3H 21 | 10 |
