Guessing this is probably a lost cause but I'm trying to figure out at least what went wrong. I was hit by another car on the side and caught it on the dashcam. Luckily I recorded the playback on my phone so I do have a record of it, but not the greatest quality. I thought I had pressed 'save' when it happened but apparently when I tapped the icon, I only opened the viewer. I did press 'save' again which worked properly around 20 minutes after the accident, but as you probably know, the save function only saves 10 minutes of dash cam. By this time I had stopped driving and parked so the accident was still within the last 1 hour loop. I had to go do something for a few hours and when I came back to the car, I took the usb out so just to be sure I wasn't going to write over the 1 hour loop before I started driving again. I will mention Sentry Mode was on during the parked time, but that shouldn't interfere with the dash cam loop, they save to different locations as I understand it.
However when I got home to check the footage, I find that the only footage saved was that 10 minutes and the 1 hour loop is not under the 'recents'. The 'saved' footage is from 6:48-6:58pm and just misses capturing the collision which probably happened around 6:30. In the recents folder there is only a 1 min sentry mode clip from 10:37pm when I got back in the car before I removed the USB, and then a 1 min clip from 11:14pm and 11:37pm both times when I plugged the usb back into the car to check the clips there after I tried to find them on the USB on my computer.
If I understand the dash cam correctly, there should be at least 1 hour of footage in the Recent Clips folder, but it appears by 'saving' the 10 min clip, it erased the entire hour before it. Has anyone come across this?
