DBT chargers and Chademo-adapter
Discussion in 'Model S: Battery & Charging' started by Matias, Feb 9, 2015.
  1. Matias
    Matias Active Member
    Finland
  2. Matias
    Finland
    I'm talking about these stations
    Are they same as "Nissan stations" referred in other threads?
  3. mgboyes
    mgboyes Member
    United Kingdom
    The majority of CHAdeMO units in the UK look like the one in your photo, and are DBT units supplied by Nissan.
    Currently the Model S is intentionally limiting itself to 70A on these points, to prevent them from breaking down, so the maximum it will draw is about 25kW.
    This is pretty disappointing since these units are sited at just about every motorway service station in the UK!
    Apparently Nissan/DBT are rolling out a fix.
    It is quite likely that you will only get 25kW from these units if/when you get your CHAdeMO adaptor :-(
  4. Matias
    Finland
    Ok. Thanks.
  5. Panu
    Panu Member
    Uusimaa, Finland
    Does this possible fix by Nissan/DBT cause Model S not to limit any more? Or is a fix/change needed in Model S sw too?
  6. Panu
    Panu Member
    Uusimaa, Finland
    In Finland the company that installs DBT chargers is now saying that Tesla owners should not use them at all because charging Tesla will crash the DBT charger software. Anyone seen that happen?
  7. Matias
    Finland
  8. mgboyes
    mgboyes Member
    United Kingdom
    My guess (and it is completely a guess) is that in the UK the cars have been loaded with a database of known DBT CHAdeMO sites and the car is limiting current based on its GPS location (just like it stores a reduced charge limit based on location for general charging). I'm not sure there's any way to tell what model of CHAdeMO unit you are talking to from the protocol, and certainly not to check whether or not it has been patched/upgraded/fixed. This would certainly mean that at some sites you will get the full power (because they're not in the database).
  9. Matias
    Finland
    #9 Matias, Feb 24, 2015
    That sounds plausible (if carger does not give some id-number to car). Isn't there nowadays possibility to restore factory settings in car? I would try that (of course charge limit should not be erased, but I think it is worth trying).
