How would that work? Use a Starship to decelerate the ISS and then undock the ship and return it safely to its launch site?
That's the idea, but I found the contract requirements on the
government contract site. Let's see what that gives us.
- The deorbit vehicle design and operations shall enable a contingency call-up for launch on-need to support an earlier than nominal plan de-orbit scenario. This call may be made as late as L-6 months prior to the needed de-orbit date.
- The deorbit vehicle design and operations shall support a later than nominal plan de-orbit scenario due to the extension of the ISS EOL beyond 2030.
- The deorbit vehicle shall remain on-orbit in a quiescent mode for a minimum of one year preceding the final deorbit burn.
- The deorbit vehicle design and operations shall allow rendezvous and attach to the ISS at Node 2 Forward.
- The deorbit vehicle design and operations shall allow for operational scenarios including both a crewed and uncrewed ISS.
- The deorbit vehicle design may require complex software development including autonomous operations and failure response late in the deorbit phases.
- The deorbit vehicle is a must-work function.
- The deorbit vehicle shall be capable of providing at least 47 m/s of delta-v for the ISS at 450,000 kg mass.
- The deorbit vehicle shall provide a minimum total thrust of 3236 N.
- The deorbit vehicle shall provide attitude control for the mated stack throughout the deorbit sequence of events.
The ISS is a 450 ton object that needs a 47 m/s shove. NASA calls for a minimum thrust of 3,236 N. They also call for "a must-work function". That suggests that hypergolics would be the way to go. Draco thrusters produce 400 N, so they'd need 10 of those to fill the requirement - but they're designed for short bursts. A SuperDraco thruster produces 71,000 newtons, so just one of those would be more than enough to meet the requirement - except that they're designed/packaged for a 25 second burn.
Quick math says that a single SuperDraco firing for 5 minutes would impart the needed shove to a 450 ton object, producing 0.016g of sustained acceleration. Assuming it could run that long, it would burn through 17 tons of hypergolic propellants.
For comparison, a Merlin vacuum engine can throttle down to 626,000 N. It would fire for 34 seconds, producing 0.14g of acceleration.
A Raptor vacuum engine can throttle down to 1,000,000 N. It would fire for 21 seconds, producing 0.22g of acceleration.
The minimum thrust requirement would involve a 1 hour 45 minute burn, producing 0.0007g of acceleration.
Each of those numbers ignores the mass of the tug vehicle.
I have no idea what sort of accelerations the ISS structure can tolerate without fear of breaking up.
The challenge for SpaceX would be ensuring that they have "a must-work function" system. Hypergolic fuels are extremely reliable, but if SpaceX can get Starship reliable enough in seven years, then they could use a Starship tug variant and easily move the ISS wherever it needs to go.
Using Starship would be interesting because the mission would have to involve a time when the ISS is passing over the right area of the Pacific ocean and also passes over Starship's landing site. Starship would be deorbiting itself as it deorbits the ISS, so after detaching from the ISS it would have to boost to some degree if it's going to make it to its landing site.
Absolutely not required. What little does survive entry is the reason for targeting Point Nemo in the uninhabited South Pacific.
I'm aware. I prefer the idea of vaporizing the entire thing so that more crap doesn't reach the sea floor - or float around in the ocean. I would expect some sizeable pieces to make it to the surface. The Russians calculated that 20 tons of Mir would reach the ocean, most of it small stuff. The ISS is three times the mass of Mir, suggesting 60 tons. I would assert more would make it because the larger the object, the more it shields its own mass from heating. So some rather large chunks could make it down. Blasting it into smaller pieces during interface would aid in ensuring that very little makes it down. Ideally, none at all. Well, ideally we stop deorbiting mass that cost a fortune to get up there in the first place.
I'm just musing because I can't imagine anyone sending explosives up to the ISS.
