Here's another:
DRIVEN: Detroit Electric’s electric Lotus Elise
Let's see the specs:
Based on the Lotus Elise
150kW (200hp) motor
0-100km/h (0-62mph) in 4.3 seconds
220km/h (137 mph) top speed
325km (202 mile) range
200,000km (124k miles) expected life of battery
Hmm, what car does that sound like?
Edit: Ironically, after watching the videos, I noticed the car
literally sounded exactly the same as the Tesla Roadster.
240v 10A charges it in 6.5 hours. (fishy numbers 240*10*6.5 = 15.6kWh, should be impossible to travel 200 miles with just 15.6kWh, that's just 78Wh/mi)
240v 35A in 3.5 hours. (This one gets 240*35*3.5=29.4kWh, bit more believable)
240v 100A charges it to 80% in 10-15 minutes.
The engineer claims his motor is revolutionary because it is it makes 5kW per kg, while typical motors make 0.25kW per kg. The Tesla's motor makes a peak of at least 250hp=186kW, weights ~70lbs=32kg, so 5.8kW per kg.
Anyways perhaps this will be a less expensive version of the Tesla Roadster.
Edit: An interesting point is the electric Lotus Elise prototype seems to have kept the standard transmission from the original Elise. There is a clutch and at least three gears (I assume it has 5 gears, but the author only talked about shifting to third gear). I wonder how long a standard gearbox will last used this way.
