All parts from Homedepot. Receipt for reference (exclude the first item).
3/8 diameter is larger than the whole on factory plate so need to be pushed harder to get through.
Part list:
3/8 in.-16 x 8 in. Zinc Plated Hex Bolt
3/8 in.-16 Zinc Plated Hex Nut
3/8 in. Zinc-Plated Split Lock Washer
3/8 in. Zinc Flat Washer
5/8 in. Zinc Flat Washer
Part list:
Everbilt 3/8 in.-16 x 8 in. Zinc Plated Hex Bolt 800936 - The Home Depot
Hex bolts are hexagonal head fasteners with machine threads. They are commonly used for machinery and construction projects, both residential and commercial. Fully threaded sizes provide excellent grip
www.homedepot.com
Everbilt 3/8 in.-16 Zinc Plated Hex Nut 801756 - The Home Depot
Hex nuts are widely used in construction and to create a bolted joint. They are available with coarse or fine threads. Use with a screw or hex bolt to create a strong connection.
www.homedepot.com
Everbilt 3/8 in. Zinc-Plated Split Lock Washer 20246 - The Home Depot
This split lock washer provides a circular bearing surface with offset split ends which help bite into the mating material to provide a locking feature when tightened beneath a nut. It is round with a
www.homedepot.com
Everbilt 3/8 in. Zinc Flat Washer 804586 - The Home Depot
Flat washers are essential fasteners to keep on hand. They are used with a bolt or screw to evenly spread the load over a wider area. Flat washers also prevent loosening due to vibration, stop the bolt
www.homedepot.com
Everbilt 5/8 in. Zinc Flat Washer 804606 - The Home Depot
www.homedepot.com
