No.Is it necessary to precondition for charging at home?
NoIs it necessary to precondition for charging at home?
NoIs it even possible?
Pretty. much yes (although the term "pre conditioning" also refers to conditioning the car CABIN (not the battery) for occupant comfort, and people do that all the time.Or just for going to superchargers?
You can start the remote climate control to pre condition (get the cabin to a comfortable temperature) anytime you want to, but in general it only takes 10 minutes or less for the CABIN to reach a comfortable temperature. Trying to pre condition the BATTERY for charging is ONLY necessary as it pertains to getting the best charging speeds out of a supercharger, not a home charger. It only happens when a supercharger is set as the destination.And is it important to precondition before you drive everyday even if it's not cold or hot outside?
Yes kind of, but not really. It only warms the battery a little bit. If it’s really cold, departure preconditioning will still not be sufficient to fully warm the battery for full regen.Actually, per the Owner's Manual, preconditioning before departure will warm the battery and the cabin interior and side mirrors. This enables full regenerative braking when you start out.
Yeah I was asking about both, I was just curious if preconditioning before you drive is better for the battery regardless if it's to hot or to cold or if those are the only conditions that it helps.I think that you're talking about two kinds of pre-conditioning....
The only way that you can pre-condition (i.e. heat) the battery for Level 2 (L2 - 240VAC) home charging is if you tell the navigation system in the car that you're headed to a Supercharger. And you really won't gain all that much in charging efficiency but you will waste energy. Pre-conditioning, in this sense, is only for Supercharging as it forces a lot more current into your battery than L2 does.
As far as pre-conditioning before driving I think that you're talking about heating (or cooling) the car's interior in order to make a more pleasant atmosphere for the driver and passengers. That can be done while the car is charging so that you are essentially using your home's electrical supply to heat (or cool) the car and not the car's own battery (which would reduce the range). It's up to you if you do that or not.
How does preconditioning ensure your battery is full when you want to leave? I'm 4 years into Tesla ownership, I've never preconditioned, and my car always leaves with exactly the level of charge that I desire.I believe the preconditioning it better for the battery and it ensures I’m full when I want to leave
Without ore conditioning The car doesn’t know when I want to leave. But in order for the car battery to be optimized it lowers the charge and then recharges it. So for example you could unplug your car when it’s not quite at the full charge because it started the decent. Preconditioning ensures that doesn’t happen.How does preconditioning ensure your battery is full when you want to leave? I'm 4 years into Tesla ownership, I've never preconditioned, and my car always leaves with exactly the level of charge that I desire.
Without ore conditioning The car doesn’t know when I want to leave. But in order for the car battery to be optimized it lowers the charge and then recharges it. So for example you could unplug your car when it’s not quite at the full charge because it started the decent. Preconditioning ensures that doesn't happen.
If you're concerned about it just use the Departure Time feature. Then the car knows when you want to leave.Without ore conditioning The car doesn’t know when I want to leave. But in order for the car battery to be optimized it lowers the charge and then recharges it. So for example you could unplug your car when it’s not quite at the full charge because it started the decent. Preconditioning ensures that doesn’t happen.
But it is a simplification in the manual.Actually, per the Owner's Manual, preconditioning before departure will warm the battery and the cabin interior and side mirrors.
Is that based on your logging or do you have another source?its only to about 5C or so
Yes, logging and also have a tablet with scan my tesla in the car all the time.Is that based on your logging or do you have another source?
There is a big difference in regen as lithium batteries must not be charged below 0C and tesla do not allow regen if the cell temp it about 3C or below on the LR/P packs.I'm asking because I have an LFP battery, and in my climate (overnight temps typically 1-3C), there is a massive observed difference in regen with preconditioning. Maybe 5C makes all the difference, or maybe LFP is heated differently?
Yes, you’ll se that during the winter.Having said that, even after preconditioning, there are still dots on the regen display, and sometimes a "regen limited" icon on the side.
