A buddy of mine just received his new Raven Model S and he says the NEMA 14-50 adapter no longer comes with the car. He says that he is being told that it is add-on accessory. Is that right?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks everyone. This is an incredibly stupid move on Tesla's part.
I suspect this move will result in 1-2 fewer garage fires per year over the next 10 years, though.
There is an incredible range of quality in NEMA 15-50 recepticals; the majority of plugs installed or purchased by consumers are for appliances that are unplugged / re plugged once every 7 years when the appliance breaks.
There *are* plugs that are able to tolerate getting unplugged/re plugged weekly; those are $50 receptacles.
With the expansion of the supercharger network, the days of needing to fill up at a trailer park are probably gone for 80% of tesla buyers.
When you get a charging setup for your house, get a hard-wired EV charger, not some mickey mouse thing that will kill your kid if they plug it in wrong or catch fire because the plug wears out.
(of course, I'm ignoring my own advice, I got a probably-not-appropriate plug (nema 6-20) installed and I'm using my mobile charger with it, but I'm also not actually sure if a 20a/240v circuit is sufficient to keep my car working over the winter in Boston, so I'm hedging my bets before buying a real outdoor charger like this; I really don't want to face adding a 40a or larger circuit to my existing antiquated 100a service).
A couple of things to note here...
First up, "get a hard-wired EV charger" isn't as simple or cost effective for all. Some have VERY expensive installs in order to install a HPWC and it could run several thousand dollars. One person I know parks on the other side of the house from his panel and service as they're both on the opposite side of his house. Due to this, he got quotes approaching $10k just to install a HPWC. Yikes! In his situation, he already had a NEMA 14-50 so he was able to achieve perfectly acceptable charge rates for basically free.
Secondly, the cause of NEMA 14-50 failures/fires is improper installation more often than not. If the wire isn't fully stripped so the wire lands properly and is fully tightened this can cause resistance and over time this will be a bit time no no. Rarely is a fire caused due to being plugged in and unplugged repeatedly. The spring tension on these sorts of receptacles will survive thousands of plus/unplug interactions. If you're concerned about it you can replace the receptacle every few years or so at the cost of ten to twenty bucks. Doing this you also increase the likelihood of improperly landing one of the wires at some point.
The bottom line is that we want them restrict our options LESS not more due to a few outlier issues. When you own an EV there is a certain number of inherent risks this comes with. Being able to charge quickly is a necessary evil for most and running more juice steps up the potential for danger. Just the nature of the beast.
Offset this with the elimination of gas cans and other flammable chemicals that most store in their garage for your ICE car and you greatly decrease your odds of a fire even with a NEMA 14-50 that you plug in and unplug hourly just for fun.
Summary: removing the 14-50 adapter greatly hampers progress with the average consumer they're going to need to win over if they wish to remain relevant once all the fanbois have bought their Tesla already.
Your suggestion is to pay to pull a perfectly functioning 240-volt, 40A outlet to install a HPWC that gives you 240-volt, 40A service? That seems like a good suggestion to you?If there is an existing NEMA 14-50 in a convenient location, why not just simply remove the receptacle and hard-wire a fixed charger in that location? No need to pull another circuit for $30 or $10,000. If you really need both, there are ways of putting a sub-panel there to allow you to use one or the other circuit while not overloading the feed. Again, this will cost far less than $10k. You could even just buy the NEMA 14-50 plug from Tesla, and inspect / replace the NEMA 14-50 receptacle, but that's clearly less safe than a hard-wired installation.
A simple google search for "tesla nema 14-50 fire" gives:
NEMA 14-50 Plug Meltdown / Near Fire
My NEMA 14-50 nearly caught on fire Friday night!
PSA. Another melted NEMA 14-50 receptacle
Your list of Google results has no affect on this.
Some "random plug" of "unknown origins" huh? You're really reaching to try to seem right to people reading who might not known any better.Yes. My suggestion is to replace a receptacle of unknown origins with a hard-wired charger.
A hard-wired charger won't electrocute you and won't catch fire. It will also charge faster than if you use a NEMA 14-50 plug on a mobile connector, which will limit the charging to 32 amps.
Using a NEMA 15-40 is safe as long as you're using one that's properly installed and using one that's suitable for the way you plan to use it. Some random plug, well, I guess that's what insurance is for.
Your posts also do nothing to address that as soon as you pull out of your garage your HPWC is worthless and you're now limited to excruciatingly slow speeds as you travel. NEMA 14-50 outlets are everywhere and you can't plug into them w/o the adapter.
Note that I never said the HPWC was a bad option. Tesla FORCING this option onto consumers is bad as it's not best for every situation.
So now we should fear every single electrical outlet and all of the electrical work done in our homes? ROFLYes. Some receptacle in your garage or laundry room that was installed when the house was built is the definition of "some random plug". You didn't observe it being installed, you didn't specify that you wanted a more expensive typically unnecessary heavy duty plug. You didn't emphasize to the electrician that they need to be especially careful about installing it because this particular plug will be wrung to the absolute limits, run at 80% of maximum for 8 hours at a time. Most other uses of this plug do not draw 80% of the maximum current for hours at a time so any flaws in the installation or device simply don't matter.
When you're out and about, sure a NEMA 14-50 is probably handy to have in your bag of plugs. A TT-30 is probably also handy. A NEMA 5-20 is probably also useful. I personally have a NEMA 6-20 because I had one installed outside next to my driveway where I had an already existing 20amp 120 circuit; I had it rewired to be a 240 circuit, and if it is sufficient for the winter, I'll replace the plug with a hardwired 20a EV charger instead of relying on my mobile charger.
You're playing with fire if you use one of these things day-to-day in some random plug in your garage. You're playing with fire if you regularly charge at your in-law's garage where they've got a NEMA 14-50 that hasn't been used in the 20 years since they've moved in.
But hey, your stuff, your rules. Do what you're gonna do. You'll probably be fine.
Hi. I'm in Boston and cars live outside. My first PHEV was a volt with 3.3 kw (14amp)Clipper Creek hardwired and mounted outside. My MS75D is two years old and I also have a PHEV Pacifica. Both are serviced fine with the same unit at 3.3 kWh (10mi/hr). Tesla with 14-50 adapter. I have a HPWC but haven't installed since no need and will wait for the CC to fail first.I suspect this move will result in 1-2 fewer garage fires per year over the next 10 years, though.
Why can we trust the electricians who install the HPWC but not the ones who install 14-50 outlets? Is it extra training? Stock holdings?
