True, but I'm not sure they would be able to do that in the space available.
The only detailed information I can find is for the 85KWh battery pack, things may have changed since this information was shared. That pack consists of 7104 cells across 16 modules. Each cell is 3.6vdc at 3350mAh with a maximum discharge rate of 4.8A. Each module is comprised of 6 groups of 74 cells, so a group is 74 cells in series and then 6 of those groups in parallel. So 74 cells gives a voltage of 266.4vdc which means something is off, because that would result in a group voltage of 1598.4vcd which I know isn't correct.
The math doesn't work out, but I'm backing into it. Tesla may be doing things different or sourcing parts different than what I can obtain detailed information on. Do we have any Tesla engineers here to shed some light? Is this information that Tesla is even sharing with the public?
Why would it take any more space to wire in series than in parallel?
And you have it wrong, it is 6 groups in series with 74 cells in parallel in each group. (Each module is about 25 volts. Then the modules are run in series.)
Info in the 100kWh pack is here: Pics/Info: Inside the Tesla 100 kWh Battery Pack
Summary:
- 516 cells per module. That's 8,256 cells per pack, a ~16% increase vs the 85/90 packs.
- The BMS reports a max discharge current of 1,760A for the P100D Ludicrous pack. The normal Ludicrous P90D/P85D packs report 1,520A. This makes perfect sense with scaling, since it's 74 vs 86 cells per group.
My point was that adding additional capacity, without adding voltage, would be difficult because of the physical limitations of space required to house another complete module.
They didn't add an additional module, they redesigned the modules to fit ~16% more cells in the same space.
