Will changing the tire type in the "reset tpms" screen also recalibrate the speedometer?
If yes, then would it also be true that as long as the wheel diameter is the same then the speedometer accuracy will stay the same?
If both of those are yes, then selecting the Track Pack 20" from the TPMS sensor would mean there's only a 0.75% diameter difference if you want to put 255/45/18 tires on your car, but if it doesn't reset then there's a 1.86% difference instead.
