wiztecy
I have the Griots charger also, and ran into blowing fuses when I used it with my Lotus Evora a few years back. So I carried extra fuses and just ignored it. I have since put it in my Roadster, but didn't really think about testing it in the lighter socket, but I would assume it may be the same issue based on what others are saying.
Would it make sense to carry something like the following?
battery-cigarette-lighter-extension on Amazon
I don't know how easy or difficult it is to get to the small 12V battery under the front passenger fender, but this seems like it might work much better getting the power directly from that battery. Thoughts?
If you want to hook directly up to your 12v battery, I'd use the battery tender wire connection below. That way you can disconnect it. It also has an inline fuse.
Battery side:
Amazon.com: Battery Tender 081-0069-6 Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug: Automotive
Plug with the cigarette lighter that you can keep in your trunk:
Amazon.com: Battery Tender 081-0069-8 Female Cigarette Adaptor for Quick Disconnect: Automotive
