Door handle doesn’t fully retract
Discussion in 'Model 3' started by Darthbenji, Feb 25, 2020.
  1. Darthbenji
    Darthbenji Member
    Ontario
    Not ice or snow related. It’s the driver side rear door handle and it will retract about 75%. Is it safe to squirt a little wd-40 in there?
  2. pscarroll
    pscarroll Member
    East Coast, USA
    Probably. What about Astroglide? What about Tesla Mobile Service?
  3. jkoya
    jkoya NA2 NSX
    Northern CA
    • Informative x 3
  4. smatthew
    smatthew Active Member
    CA Bay Area
    Maybe you should post in the S or X sections of the forum.
  5. pscarroll
    pscarroll Member
    East Coast, USA
    Well the Model 3 handle kinda retracts, more like pivots manually.
  6. SlimJim
    SlimJim Member
    wd40 is not a lubricant....
    silicone grease is.
  7. UKNOWINVU2
    UKNOWINVU2 Member
    Canada, Ontario, GTA
    I brought up the same issue for my model 3 at the service center, they added some silicone lubricant to the handles which seemed to fix the issue. Doing this will definitely cause the lubricant to drip down the outside of the door, I would wipe that away as quick as possible.
  8. M109Rider
    M109Rider Active Member
    Kitchener, Ontario
    I believe WD40 was recommended because it is a water displacement product. If ice was the issue, it would temporarily lubricate, and remove the water.
    If it’s just a lubrication issue, and not water or ice related, then I wouldn’t use WD40.
  9. CharleyBC
    CharleyBC Active Member
    Talent, OR
    We had this problem on the driver’s door. I just fixed it Sunday using the technique in post #3 above. Works fine now. Time will tell how well it lasts.
    Pro tip: do it in good lighting conditions so you can see the pin and spring depicted in the instructions. When I first looked in my garage, it was a black hole. Out in the sunny driveway it was obvious.
