And properly launch on a good surface?Did you precondition/heat the battery?
And check your own weight?
You didn’t use dragstrip mode?I don't think dragstrip mode is going to make any difference. Especially how soft the car launches now.
Not yet. I plan to do it when I have more time. I can see where it would potentially help the Plaid more than the LR. If I had to make a bet, I doubt it will make any difference since Tesla says basically it just pre-warms everything and lowers the CG. The car just came off the charger, it was a pretty warm day, and a few full throttle runs would tend to warm up everything anyway.You didn’t use dragstrip mode?
I use the S3XY buttons to measure battery temps and “Max Discharge” in my Model 3 Performance.Not yet. I plan to do it when I have more time. I can see where it would potentially help the Plaid more than the LR. If I had to make a bet, I doubt it will make any difference since Tesla says basically it just pre-warms everything and lowers the CG. The car just came off the charger, it was a pretty warm day, and a few full throttle runs would tend to warm up everything anyway.
Previously I ran dragstrip mode without anything to measure the acceleration before. I couldn't tell any difference as far as rate of acceleration. Just to rule out something else, I'll do it but if it makes more than 0.2 seconds difference, I'll be shocked.
So you expect it to perform at its peak performance numbers without optimizing it including by using the settings that explicitly are for peak performance.Not yet. I plan to do it when I have more time. I can see where it would potentially help the Plaid more than the LR. If I had to make a bet, I doubt it will make any difference since Tesla says basically it just pre-warms everything and lowers the CG. The car just came off the charger, it was a pretty warm day, and a few full throttle runs would tend to warm up everything anyway.
A couple of things about drag strip mode:Not yet. I plan to do it when I have more time. I can see where it would potentially help the Plaid more than the LR. If I had to make a bet, I doubt it will make any difference since Tesla says basically it just pre-warms everything and lowers the CG. The car just came off the charger, it was a pretty warm day, and a few full throttle runs would tend to warm up everything anyway.
I am not saying there isn't some benefit, I highly doubt it is worth .4 seconds. If you have to do all this just to get it to run 3.1, that is pretty sad. Like I've seen, the M3P, with absolutely no prep, across several examples I've seen, easily runs very close to it's claimed 3.1 time. Granted the 3.1 seconds are measured slightly differently so they aren't directly comparable but it still ran what it should have compared to the claim.So you expect it to perform at its peak performance numbers without optimizing it including by using the settings that explicitly are for peak performance.
I haven’t seen much variance in 0-60 mph times until I changed to lighter wheels. Up top is where I have seen differences with temps and SOC. Preconditioning seems to affect 1/4 mile trap speeds tremendously.I am not saying there isn't some benefit, I highly doubt it is worth .4 seconds. If you have to do all this just to get it to run 3.1, that is pretty sad. Like I've seen, the M3P, with absolutely no prep, across several examples I've seen, easily runs very close to it's claimed 3.1 time. Granted the 3.1 seconds are measured slightly differently so they aren't directly comparable but it still ran what it should have compared to the claim.
Another counterpoint is running my 3. Cold pack, not a warm day, not even full charge, and it still ran very close to what Tesla claimed. No preconditioning of the batteries.
If the only way the MS LR will run a 3.1 0-60 is going through all the hassle of drag strip mode, it will be pretty sad. If this is what you have to do to get the LR to run the claimed times, then they should not that somewhere. It also means you might not want to run an M3P on the street either.
I don't think the LR is having traction issues like the Plaid might. It has the same amount of tire as the Plaid and 300+ HP less.
With my car, I have not seen much variance with SoC, at least for 0-60. Even on the 1/4 mi, my fastest run was at something like 80%. Conditioning definitely makes a difference, somewhere around here I posted pics of Draggy runs before and after.I haven’t seen much variance in 0-60 mph times until I changed to lighter wheels. Up top is where I have seen differences with temps and SOC. Preconditioning seems to affect 1/4 mile trap speeds tremendously.
I saw a full weight Plaid with stock 21” wheels running 9.27 @ 157 mph on a really well prepped and FAST track. Charging to 100% at the track and preconditioning with cheetah and Drag mode seemed to help there.
Even running 0-60 times will give me useful data. I have no good areas where I can really run the S out. In the 1/4 mile I would be in the mid to upper 120's. I have no track nearby to run the car on. So running those speeds on a public road are a recipe for going to jail here. I already have that problem with my really high performance motorcycles.Making any judgments with just 0-60 on Dragy is not worth the effort. Much better to use at least 1/8 mile or better 1/4 mile which gives you a longer time, a longer curve, and the crucial 60 foot times that tell you what is happening at the start with traction.
0-60 is for marketing and car magazines.
1/8 mile and 1/4 mile on a proper surface (which you can tell by the 60 foot time) is for actually making any intelligent informed determinations about your car and whether it is performing at its peak.
Is there such an app available for model S plaid / LR ?I use the S3XY buttons to measure battery temps and “Max Discharge” in my Model 3 Performance.
I have seen as low as 432 KW for “Max Discharge” and as much as 462 KW with 90%+ SOC.
I have seen as much as a .3 second difference for the 1/4 mile between a fully preconditioned battery and one that doesn’t have temps optimized at all.
Preconditioning is the single most important thing for improving performance of my Model 3 Performance. Maybe it is different for the S but I doubt it.
I never have been able to get better than 2.12 on the plaid (gutted) on street. there is just not enough traction at least on the roads around here.Sorry if it’s already been discussed but what impact does ambient temperature have on the plaids performance? Say 100F vs 75F. Also, does anyone know if the car shuts off the AC compressor at full throttle as an ICE motor would.
Pulled out my dragy and did a non drag mode launch with ac on and very hot, over 100 ambient. Was surprised to see 3.1. After I left gym and car had a while to cool off and ambient dropped to low 90s it did a 2.5 and pulled much harder (ac off). This was roughly half a percent uphill as well. Id love to try some more and get a 2.2 so I know my plaid is performing as well as it should.
On dragy it shows that anything past 1.3g accel result in wheel spin on street. stock 19" with stock pirellis
