Since the update, my LR AWD range at 80% has dropped from 241 to 237. This implies that the range is only 296. Any idea why, has anyone else experienced this, and should I be concerned?
I am having similar issues. Before the update my rated range has also been 312-309. After the update it’s been on a decline from 309-304 and still dropping.
This could be due to a lot of different variables. The season is changing and winter is coming?
There are about 20 other threads on the same topic that happen every update... just substitute <whatever update was current then> for 2019.36.2.1 in a search. There's someone on here who has a cut-n-paste who will likely paste links to the 20 threads....
I will sum up the responses you will get:
1) "I was in the service center and <random tech> told me there is a bug in the battery systems software and it will be fixed in a future update." Note: This has been about 10 updates running now.
2) "You didn't actually lose range, it's just the battery management software losing 'track' of where the top/bottom of the battery are."
3) "Change your display to % instead of miles and enjoy your car!"
4) "YOU THINK THAT'S BAD... CHECK OUT MY RANGE - IT'S 1 MILE LESS THAN YOURS!!?!"
5) "This is normal for li-ion batteries"
6) The completely mis-informed: "Your car is just adjusting to your driving habits and/or it's cold so you have less range"
