From what I have seen, my impression is that if your max amperage is set at or below 40 A then only the master is used. At 50A, it appears to use 25A/ea for master and slave. I haven't tested 41-49A.
This based on seeing the amperage rampup "stall" at the halfway point of the max amperage in the range [50,80]. My interpretation is that this stall is the wakeup+negotiation with the slave charger.
Just an impression. Could be totally wrong.
