Economics of charging an EV
Discussion in 'Charging Standards and Infrastructure' started by Edgar_N, Jan 4, 2012.
  1. Edgar_N
    Edgar_N New Member
    Quick question -- do EV chargers continue to consume/use electricity while plugged into the EV, after the EV has fully charged? I am trying to determine whether they use more electricity in this "dormant" (I don't know the correct term) state than a typical home appliance. I don't think I have seen that factored into discussions about how much it costs to charge a EV....
    Thanks in advance for your responses.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The Tesla Roadster, under normal environmental conditions, consumes very little power when not charging. It loses less than 1% of the battery pack capacity a day. In Standard charge mode it will top up the car once a day. In Storage Mode it will allow the charge to slow deplete to a low level, then it will charge periodically to maintain that.
    Under more extreme conditions it will use some extra power; for example, if the garage temperature is well below freezing it will occasionally draw some power to keep the pack warm (unless in Storage Mode).
  3. Kevin Sharpe
    Kevin Sharpe Active Member
    Bradford on Avon, UK
  4. Edgar_N
    Edgar_N New Member
    Awesome. Thanks for the prompt responses.
