Elon states 3rd row seats will be removable in Model X, plus more from interviews
A user on facebook has gathered together all the new info from Elon's talks in Norway this month, including some interesting Model X items:
Tesla Supercharger network - Page 385
More details, including ski trip needs:
Elon and JB speak in Oslo Feb 1st 2014 1000 CET (4AM EST) - Page 4
3rd row seat in MX is removable and space can be used for cargo.
Based on feedback Elon liked the ideas of removable 2nd row in MX (like for a moving van or business purpose) as well as a cover for the trunks to help with dog hair lol. He said they will look into adding these (good suggestions). Also someone asked about disabling stability control. He said that is illegal (in the US) but person responded "yes but not for track use" (which I guess they never thought about) so he said they would also look into this.
Some talk about battery size and range for MX and someone asked whether or not they'll be a bigger battery to match the range of MS. He talked about how "the norm standard" is that everyone accepts that SUVs are typically 10% less efficient. MX design challenge is 2-3x harder than the MS. Bigger front area and higher ride height and much more drag. However, he did that that due to the AWD of the MX there are some very cool unique things you can do to increase efficiency that you can't do in a RWD and it sounded like these improvements actually offset drag so that the MS and MX range are the same. Actually here in just going to copy paste instead of trying to explain:"A(EM): Challenge with the X is not the AWD but the fact that the car will have a greater frontal area, and slightly higher drag coefficient. Energy consumption about 10% greater per km. Unrelated to power train. A(JB): Typical experience of AWD is that the efficiency will be worse. We've worked really hard to not have that same effect. We found some clever ways with dual motor AWD, not just mechanical linkage. To make that an efficiency neutral option. Breakthrough."
Q1: If we already have the S, why should we buy the X?
A(JB): One great benefit, other than more space, is AWD. Lot more cargo space. Full seven passengers. More ground clearance.
A(EM): Preference issue. Sedan vs. SUV. The X will be bigger, obviously taller. Handling and acceleration will be better on sedan than SUV.
Q13: Dimensions of Model X? Falcon doors and roof. How are we to bring our skiing stuff into the mountains?
A(EM): Design of the X has been a very hard design problem. Aesthetics and functionality to work together... particular difficult for SUVs. Want it to be as stunning as one can make an SUV. The design problem for the X is 2-3x harder than for the S. Wheelbase the same, and overall length very very close... to Model S; within 5cm on length. Height shouldn't be a problem for normal garage. Maximizing internal volume when looking at packaging for the doors, for example; rigid but not deep.
A(EM): With both doors open, there's a triangular space between the doors. Place for a ski box potentially. Other place would be on the inside, slide it longitudinally under the seats.
Q30: Model X...Sig reservation 1. When? Hopefully the time between the launch in the U.S. and Europe will be shorten than for the S.
A(EM): S was the first car we made ourselves completely. We wanted the first units near to the factory and engineering center. A lot less changing about the X, and more infrastructure. Gap between initial production and arrival to Norway should be much shorter... a couple months. Guess around middle of next year for the X to arrive here (Norway). Volume production of the X in U.S. will probably be end of the first quarter next year.
