Engineered durability ?
Discussion in 'Model 3' started by Nick V., Apr 26, 2016.
Tags:
  1. Nick V.
    Nick V. New Member
    South Hadley, MA
    Does anyone understand how many miles the Model 3 is engineered for before it starts failing. Thanks for any input.
  2. Nick V.
    Nick V. New Member
    South Hadley, MA
    Drive train, electronics etc.
  3. S'toon
    S'toon Knows where his towel is
    AB
  4. Tree95
    Tree95 Member
    Usa
    I have a friend who works there. He says the target is 109,405mi
    • Funny x 10
  5. Fred Thompson
    Fred Thompson Member
    109,405 is not much, my 2004 Prius has gone 225,000 miles will relatively no problems.
  6. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
  7. BluestarE3
    BluestarE3 Active Member
    Norcal
    Given that it's such a granular number, rather than a round one, I'm sure it was meant as a joke.
  8. Skotty
    Skotty 2014 Model S P85
    Kansas City, MO
    It will be engineered for infinite miles, but entropy has other plans.
  9. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    No one except the Tesla drivetrain engineering staff can answer your question with any degree of accuracy. Everyone else is simply guessing or, as demonstrated by some posts in this thread, joking around and having fun with your question.
  10. LastGas
    LastGas Member
    South Carolina
    I read somewhere that the design life of a Prius is 250,000. I got 142,000 with no problems. Replacing it with Model S Monday.
    • Like x 4
  11. dsvick
    dsvick Active Member
    NE Ohio
    It's an electric motor, just like your refridgerator, how many miles on your fridge? :D
  12. eisbock
    eisbock Member
    United States
    The motors and battery should last a long time. It may not have the punch it once did and the range will likely be decreased, but those should keep on kicking.
    What I'm more worried about is the suspension and drivetrain. Tesla has instilled zero confidence that these are durable or reliable. You don't hear about it because people love their car so much, but lots of people reporting they've had more drivetrain replacements than fingers on one hand. Yikes. That's completely unacceptable for any car and doesn't happen with any other car manufacturer.
  13. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    Motors = Drive-train OR Motors <> Drive-train? Which is it? I see many posts where people have had +5 drive-train replacements, which seem to have included the motor. So, can someone clarify what the difference is? Thx.
  14. mspohr
    mspohr Well-Known Member
    Most of the "drive train" replacements have been for odd noises (klunking, etc.) in the drive shafts and not any problem with the motors themselves. They usually replace the entire drive train since it is easy to take the entire thing out and replace it. They send it back to the factory for reconditioning. They don't want the service centers spending time taking apart the drive train to repair it since the factory has the trained people and parts.
  15. habanero69
    FLorida
    Thanks. I thought that would make sense, but wasn't sure. Motors have been around way too long to not be able to run nearly forever. Aside from bearings, everything else should practically last forever if not damaged or contaminated, etc...
  16. N5329K
    N5329K Active Member
    ...or subjected to repeated "Watch this!" 0-60 abuse.
    Robin
  17. Model 3
    Model 3 Active Member
    Norway
    Should we count them from the shop or from the manufacturer (half way around the globe ;) )?
  18. Sparky22
    Sparky22 Member
    Toronto
    Speaking of power train, I understand there is no transmission, but still there must be some kind gear fluid which might need changing. Maybe owners of MS might know?
  19. mspohr
    There's a differential which takes the output from the motor and drives two half shafts. It requires lubrication just like any differential. In fact, some of the early problems with the "drive train" were due to insufficient lubrication in the differential.
  20. Fred Thompson
    I had to call my son that drives my 2004 Priuis ten months out of each year to get an exact mileage number that is 214,183 miles. He is going to love it when I replace the Prius with a model 3.
