Installed the parts last night and so far no luck getting it to operate. Verified all connections are good, no bent pins or damaged wires (visibly at least).
When attempting to actuate the frunk, the main release activated but struts are not powered. When closing, no power struts and soft close isn’t catching or operating either.
the ECU is flashing a single red light every second. I followed the initiation sequence (hold black button) as well. Attempted power cycle of ECU (unplug, replug, initiate) and no luck.
any one else run into this and identified solution. I checked the power pins for the struts as I’ve read that could be an issue as well as swapping them around.
reached out to support but they are 15 hours ahead so it’s a lot of “message tag” as they respond in the middle of the night.
Thanks in advance!
Thanks in advance!
