If you have to ask the question I’m guessing, no disrespect, you haven’t done it?How early are those that set the washing machine to run getting up? A machine that finishes at 4.30 would sit for a minimum of 2 hours in my house, surely the clothes start to smell after that long?
How much bacterial growth are you Expecting in 2 hours in clean clothes and water?How early are those that set the washing machine to run getting up? A machine that finishes at 4.30 would sit for a minimum of 2 hours in my house, surely the clothes start to smell after that long?
I concur with exactly what you’re saying. I’ve done the same and viewed the energy usage and on various cycles so, as you say, can start the dishwasher on an eco cycle then after an hour start the washing machine. The latter has used its energy by the time the dishwasher drying cycle kicks in 2 hours later.Regards the washing machine.
Looking at the energy usage, it is mainly at the beginning of a cycle when the water is being heated. The rest of the time the motor doesn't use very much at all.
If your cheap rate ends at 4:30, you could consider starting the was cycle at 4am. Depending on your machine, this would heat the water on the cheap rate, but not finish the washing until 6:30, leaving an hour or so before you get up to hang it out...
I do agree if the washing is left for hours damp clothes in the machine it does start to smell requiring another was which defeats the object.
Dishwashers, on the other hand tend to have a period at the beginning of the cycle where they rinse with cold water. The heater kicks in later (about 50 minutes with ours on economy) for the main wash and again for the drying cycle. There is not a problem leaving stuff in the dishwasher as the heat and chemicals sterilises everything.
With a storage heater, you're literally heating a pile of bricks with a resistivity heating element. Even the smallest storage heater is shipped in 3 parts. Heater, set of bricks 1, set of bricks 2. Afraid there isn't any way you're going to get an easily moveable version.Can anyone recommend a product to achieve the following:
- Charge overnight to set schedule, discharge programmable preferably via an app or wifi
- Discharge easily adjustable to accommodate different daily requirements but can also accommodate simple on-off
- Moveable
- Can be plugged in, not hard wired
only thing is, I think Washing machine uses much less than dryer...We now schedule the dish washer and washing machine for a cycle between 12:30 and 4:30
Every little helps
May depend on the dryer - worth a look on condensing dryers vs newer washing machines. I don't know the answer (yet) need to do a 'lone' cycle in the nightonly thing is, I think Washing machine uses much less than dryer...
mine is condensing with the heatpump.May depend on the dryer - worth a look on condensing dryers vs newer washing machines. I don't know the answer (yet) need to do a 'lone' cycle in the night
Recently swapped our ailing resistive tumble dryer for a heat-pump model. 400-600 watts is about right, but we're finding drying times to be not that much different to the old dryer. A load of towels is still around 2 hours, but things like bed sheets are dry in an hour.- A heatpump drier will pull 400-600w for 2.5-3 hours. Let's say 1.25kWh
as in my post:- A standard tumble drier is going to pull 2kw for 90m-2h, lobbing the heat out the side of the building. Let's say 3.5kWh
A 40c cotton wash is about 0.75kwh. 60c more (1kWh), 30c less..
Not a lot in it for a heatpump, but enough to make a decent saving. Only thing is, I'd be really hesitant to run a standard tumble drier while sleeping.
Steve
My post was at a 'consider' stage but I subsequently decided against this prior to reading your reply.With a storage heater, you're literally heating a pile of bricks with a resistivity heating element. Even the smallest storage heater is shipped in 3 parts. Heater, set of bricks 1, set of bricks 2. Afraid there isn't any way you're going to get an easily moveable version.
You're also looking to charge in 4hrs, when most will be optimised for economy 7.
I admire your desire to load shift, but unless you're going to fully commit to storage heaters in the house all year round (And see if you can get E7 / Go Faster), I don't think this will be practical.
